Dear all
With the help of a friend, I'm building shelves into the alcoves in my living room, one side of which will be used to store a large amount of heavy vinyl records (see pic below)
https://db.tt/9dbakYBH
We've had to mount plywood sheets to the back walls, as they were covered with dry wall plasterboard, which obviously bears no weight. We drilled through this and deep enough into the brick wall behind to make them rock solid.
I've had shelves cut to size from 18mil ply, but as they are around 130cm wide, am thinking that a supporting central strut will be neccessary to avoid bowing.
Can anyone suggest a suitable method, and the best material? The ceiling is around 2.5m high.
Thx in advance
Thx in advance
