Hi guys, long time no post
Murphys law being what it is, I know I should of left that slightly leaky radiator valve as it was bound to cause trouble... but... I meant well.
I drained the system down, replaced the offending olive and then re-filled the system. Then went round and vented all the rads to the point that no air was coming out. All seamed well until the heating kicked in this afternoon when the rad I replaced the olive on would not get warm. All other rads warned up without any problem, so I then commenced to bleed the rad above the pipes from the rad I had worked on ( the rad with the replaced olive in in the hall, with the front bedroom rad directly above).
Half an hour later I noticed that some of the other rads were cooling down as if the thermostat had turned the system off, so I upped the settings so it still called for heat.. it was at that point the system pipe work in the airing cupboard where the pump etc is made a couple of bangs and the vent pipe could be heard spluttering and I noticed that the pump wasn't running, but was too hot to touch.
I've tested the wiring to the pump and there is 240 volts between the live and neutrals so voltage is being supplied to the pump. I let the system cool down for an hour so the pump was just warm to the touch, thinking it might be some thermal shutdown thing in the pump that might be stopping it, but when I turned the system back on nothing happened but the pump got hot again... so its's off to screwfix in the morning for a replacement. Could the airlock of killed the pump ?
Malcolm
Malcolm
