Morning all.
Just spent the weekend draining my central heating and installing an extra radiator. Completely drained the system in my bungalow before fitting the extra pipework and connecting the new rad up.
Whilst the system was drained I took the opportunity to clean the PRV and pressure gauge (which were both full of gunk) Have suspected the expansion vessel to be knackered for some time (had to regularly top the system up) so while the system was empty checked it for pressure, a small amount of air came out. So following the instructions on here, used a bike pump to increase the pressure in it, then refilled the entire CH system. Bled the pump and all the rads. Everything appears to be working, rads are all good and hot, PRV doesn't drip and pressure doesn't shoot up between the system being cold and hot.
But as of this morning, noticed upon firing up the sound of rushing water and bangs from the boiler (Worscester 24i RSF combi) not everytime it fired, and would die down after 5 seconds. Suspect it's air in the system, but not sure where to go from here. Obvious ones to check are bleeding the rads and make sure the new pipework isn't leaking. If the expansion vessel is knackered, is it possible that any air I've pumped into it, could now be getting into the system, and if so, am I better off just letting the pressure out of the vessel and relying on topping the system up regularly (I'm planning on replacing the boiler in the next few months, so this would only be a temporary solution)
Any suggestions would be much appreciated
