Hi all,
Sorry for the long post
I have a few questions/queries regarding how my HW & CH are wired and how it works.
Firstly I have the following components:-
Potterton Prima 50B boiler (pump overrun connected)
SMC Comet 2-130 pump
Switchmaster 400 timer/programmer (HW or HW & CH)
Switchmaster midi mid position valve
Honeywell L641A cylinder stat
Wickes room stat
10 way wiring centre
Wiring centre connected as follows:-
1-Neutral
2-Neutral
3-Live
4-Earth
5-Boiler switched red wire from mid pos valve
6-Room stat switch yellow wire to mid pos valve
7-Cyl stat satisfied to white of mid pos valve
8-Room stat feed
9-Boiler pump control
10-Cyl stat call to orange of mid pos valve
I have recently changed the room stat to a Heatmiser PRT/HW programmable stat, I removed the room stat feed from terminal 8 and fed direct from terminal 3 to give me a permanent supply to Heatmiser, I then linked Live in to terminal 1 on stat and terminal 2 is call for heat from stat. (only CH controls used at present)The problem is I need to leave the HW permanatly on on old switchmaster 400 for CH to work through stat. This is first query.
Second query is the wiring doesn't match any S, Y, or W plan I have seen before, paperwork says Ken Grey wiring diagram, is this recognised or a one off independant?
Also my mid position valve has 6 wires where as most have only 5, why is this?
Would I be better to rewire the whole system to a recognised plan eg Y to make it easier for identifiaction and fault finding???
Would I be better to re cable
Wickes room stat
1-Neutral
2-Neutral
3-Live
4-Earth
8-Room stat feed
