what the f*ks that design ?I have to change the pipe layout, so HW and CH will be pumped. I believe that the cold fill is supposed to be nearest the boiler on the return and the vent is nearest the boiler on the flow then the pump and then the HW cylinder and then the CH flow..........is this right?
ang fire
if you have gravity h/w whats the 2 port valve for
unless its a "c" plan![]()
