I have a similar problem to a previous poster on this site, but with enough differences to make me need to post this.
I have a system that consists of a boiler (potterton but still working), indirect cistern, single pump and 3 port valve ( Siemens MA-V322C). The HW is working fine but the CH is not. There is power from the room thermostat when it is turned up high enough. I suspect the 3 port valve as the problem but am confused as to how the system works.
For example, when I turn the CH on with the thermostat up, nothing happens - no pump, no valve operation. If I manually open the valve with the small lever beneath it, the radiators get partially warm but the pump does not operate. I know the pump is working so why does the pump not operate when the heating is turned up and the valve is open? If I can understand that, then I'd be confident it is the valve, otherwise, I guess it could be a control problem.
Can anyone help please?
Cheers,
Andrew
Cheers,
Andrew
