CH performance
13 Feb 2006
Derby
2 of my 3 down stairs rads struggle to get hot (some days they get hot, some days they get warm and some they remain cold)
My thoughts are to remove these 2 problem rads and rinse through to remove any sludge ect
if this doen't make any difference i thinking of using some of the sentinal products ive seen.
How best am i to use these products as i have limited knowledge regarding central heating
many thanks
Have you balanced the radiators yet?
Is there air in the system? When you bleed a rad, what colour is the water?
Do you have thermosataic radiator valves? If yes, in which rooms?
Where is the room thermostat?
Is there a Feed & Expansion (header tank) in the loft or airing cupboard?
And, about how old is your boiler and the rest of the system?
When you say balance do you mean open and close inlets and outslets to gain optimum flow - is there a set procedure for this as i can see this being a pain.
Is there air in the system? When you bleed a rad, what colour is the water? yes the water is normal coloured
on 4 rads out of 7 rads
2 up 2 down
one of the prob rads has one.
on the stairs we never use it its set on max
yes in the loft
as old as the house Mid 80's
Many thanks for any help
When you say balance do you mean open and close inlets and outslets to gain optimum flow - is there a set procedure for this as i can see this being a pain. Have a look in the "for reference" section or do a search - there are good instructions on here. if your pump is working properly it ought to be able to pump hot water to any of the rads. Also, make sure that you can prevent hot water being supplied to the hot water cylinder once it is hot enough (look for the thermostat on the side, turn it down, feel the supply pipes to the coil - if hot water keeps going to the cylinder there may not be enough flow remaining for the rads. Start off by turning off all the hot rads and see if the cold ones go hot, or if they are still at the bottom or at the top.
Is there air in the system? well, is there? When you bleed a rad, what colour is the water? yes the water is normal coloured If it not black or brown, this is encouraging - corrosion usually makes black material.
2 up 2 down
one of the prob rads has one. Do you suppose the prob rad might have a sticking valve? Take the head off and see if the pin goes up and down, But do the balancing first.
on the stairs we never use it its set on max Is that because your CH sysytem has insufficient power, or because you like throwing money away? :wink:
yes in the loft then you don't need to use those little tubes of chemical, you can use the 1 litre bottles and pour them in the top of the tank
as old as the house Mid 80's Probably full of horrid gunge then. Try draining and flushing it to get some loose stuff out, then a cleaning chemical and drain and flush some more; then when you think its clean, refill using inhibitor. Have you found some drain-off points?
