- Joined
- 15 Apr 2017
- Messages
- 17
- Reaction score
- 1
- Country
Morning all,
I'm in the process of renovating my flat and would like to do a lot of the work myself as it's what I was brought to do with a family of tradesmen. But some advice would be greatly appreciated! I've been browsing here for a few weeks now but certain questions are unanswered and some answers are old so wondering if there are newer/better answers.....
I'm having a new boiler fitted by a local independent RGI (not touching gas, never ever, not risking it) but I would like to do most of the wet pipework and radiators etc. It's a 40yr old 2-bed ground floor flat with original Glowworm gravity boiler and copper pipe buried in the concrete screed. Most of the neighbouring properties have had leaks so betting 90%+ this one will leak when switched over to Combi!
So.... Thinking of changing all the pipework but would like an opinion on proper barrier pipe as the solution as I don't fancy copper and I want to hide it behind the skirting in a chased out channel. Longest run from boiler to hall is 15m and there will be 3 other rads between the hall and boiler. Based on experience, would you guys go for individual pipe runs in micro-bore from a manifold? Or a standard back-bone arrangement?
The reason I was considering micro-bore is the chasing out doesn't have to be particularly deep then as only 10mm. I'm assuming a back-bone feed & return arrangement would have to be standard 22mm with 15mm tails to the rads if not? Or could I get away with 15mm feed & returns with 10mm tails?
Output of the rads is quite low, it's a very warm property and requires minimal heating! Obviously I'll be clipping the pipework regularly (500-750mm depending on situation) and will be minimising joints wherever possible as well as following guidelines for cutting/fitting etc. The RGI will pressure test prior to making good!
Many thanks in advance for any and all helpful info! My RGI will help and he knows that on his next visit we're gonna be having a chat about it all but I'd just like to broaden the horizon a bit and get some helpful insight from all the pro's here
Jay
Jay
