CH room Thermostat, no live wires
25 Apr 2005
I am wanting to change my thermostat in my room for the Central Heating, as it only seems to click between 10 - 15 no matter how warm the house is.
When i removed the cover, i found 4 wires
Red - live
Yellow - Heating Control
Earth
Blue - Neutrel
The red was not live, in fact there was no power going to the thermostat.
Can anyone advise.
Probably because the programmer/timeswitch selecting central heating is off.
How wowuld I switch this on.
I dont have a programmer anywhere. Just a few controls on te actual boiler.
Theres a temp setting that is set to max for the heating, and one for the water also set to max.
When i turn down the temp setting from max, the heating stops.
Basically no matter what i do on the boiler regarding temp settings etc, the red wire never becomes live.
Why did you start another post on the subject, when you already had one :confused:
Yes i have a combi when i moved in?
Dont they require a stat??
