- Joined
- 11 Dec 2008
- Messages
- 4
- Reaction score
- 0
- Country
We have just had a loft conversion / extension done where they took out the water tank in loft and installed an unvented indirect Megaflow cylinder. We have kept our old boiler, which is a Baxi Bermuda back boiler.
For a while [about a month] all was ok. Since they have completed work in the extension, however, we have a problem with pressure dropping on the central heating system.
There is a little red expansion tank next to the Megaflow, with a dial over it. When the central heating / hot water are switched on [they are on a timer and always set to come on together] this pressure reads somewhere between 1 and 1.5 bars. But when the heating / water go off the pressure falls to zero within the space of about 20 minutes. The strange thing is that when we switch the heating / water back on again the pressure goes back up to somewhere between 1 and 1.5 bar, without us having to top up the system at all.
Two plumbers have told us that we must have a leak under the floor downstairs. Work in the extension did include work to the central heating system, fitting a new radiator and 2 fan heaters that take heat off central heating pipes, so this is certainly possible. But does this make sense if the pressure is going up again all by itself?
I know absolutely nothing about central heating systems, so please be patient with me. What I do know is that I don't want to have to dig up my newly laid wooden floor in extension.
Many thanks
Many thanks
