I'm seeing a strange one and can't work out exactly the cause or reason.
When calling for just HW on the programmer I see 240v on the Orange wire and 63v on the white wire of the 3 Way Diverter Valve. The 63v is causing the diverter valve to hold in the mid position which turns on both CH and HW.
If I then turn the HW Stat down from 60degrees to something that triggers satisfied, the 240v flips to the Grey wire and the pump stops as expected, per diagram.
I then turn off HW at the programmer, then turn the HW Stat back up to 60 degrees, turn on the HW at the programmer again and then I no longer get the 63v issue.... for a while.
Any thoughts or suggestions?
The programmer is a Tado smart thermostat.
Wiring diagram...
3 way diverter valve positions diagram...
Wiring diagram...
