- Joined
- 16 Oct 2003
- Messages
- 6
- Reaction score
- 0
- Country
HI, I might b going over old ground here, sorry if I am! I am fitting a towel rad in bathroom. needed to drain system as it needed alterations to pipework. I have a vented pumped system y layout. I disabled float valve in loft, opened bleed valves, and opened up drain valves in ground floor rads. I only got a very small amount of water out. The rad in bathroom has been removed, ok. I noticed the header tank didn't loose any water thru draining. The system now wont run properly, boiler keeps going out after a few secs and some loud bangs, so I guess there isnt enough water after trying to refill system. Pump seems to run but gets very very hot. We live in a bad area for limescale and there is quite a build up of crud on outside of pump fittings, no leaks now tho. watever i do cant seem to get system to drain though and therefore bleed properly. I did find the bypass valve had been closed off in airing cupboard, is this a sign pump/motor valve isnt working and needs replacing? I am quite happy changing components and pipework etc if someone has educated guesses to my problems.
