Hello,
I'm new to this forum as I stumbled across it when trying to identify a problem.
It seems lots have had the same problems so I was able to follow your advice and fix the boiler with not to much problems, so thank you all very much.
Now another problem seems to have cropped up.
I have a Chaff and Maury 80 boiler and had the problem with the flexi pipe to the pressure vessel blocked which I fixed, the PV needed air so I charged that and the seal to the heat exchanger from the plastic hydraulic unit was leaking so I fixed that.
The boiler ran perfectly for about a day and a half but now it keeps clicking on and off. The central heating was up to temp, the pressure correct and all seems fine but it clicks on for about 5 seconds then clicks off, then after 20 secs or so does it again and so on.
Any help would be greatly appreciated.
Brian.
Brian.
