ap-cyto said:Hi
On direct hot water only...On turning on the hot tap, the main gas jets keep lighting and then failing so water is intermittently heated.Can you help please?
ap-cyto said:Hi
Thanks for your suggestions
It turned out that the changeover valve spindle was failing to activate the microswitches reliably.
A full turn of the adjuster screw breaks and makes contact every time now.
Thanks again
Great website![]()
Yes you can, but when the water hits the ceiling you realise you shouldn't have...
Agile said:It would not have been Chris or I but it could have been you !!!!
Agile said:This is now a very old boiler
Tony
