Hi... We have a Chaffoteaux boiler installed. Basically, I wanted to know how much room should there be on either side of the flue in the cavity, or should it be a tight fit, no space on either side of the flue. I do get hot water, but in the winter, the temp gauge has to be on near max, which I'm assuming is because of the space on either side of the flue, letting all the cold air in. Water is being heated by the boiler, and thens gets cooled down by the cold air blowing through the empty space on either side of the flue.
The flue goes horizontally straight through the wall. Hope someone can help. (see diagram below) of the installation. thanks
W_________W
|E
|________________
F
_________________
|E
W|__________
W = wall
E = empty space between wall and flue
F = flue
thanks
W_________W
|E
|________________
F
_________________
|E
W|__________
W = wall
F = flue
thanks
