Hi all,
Im in the process of plasterboarding some walls in a bedroom, before I skim them. I intend to later replace the ceiling rose with an array of spotlights, and some other type of mood light in a soffit, but this will require me having a 2 gang light switch. Before I plasterboard over the lightswitch area, is there anything I can do wiring-wise that would help an electrician achieve this? Im not sure if a new wire is required, or an additional wire? Its recently all been rewired, so all in good condition. I was thinking that if an additional wire would be required later, I could feed it in the right area before plasterboarding??
