- Joined
- 31 May 2007
- Messages
- 369
- Reaction score
- 0
- Country
Hi guys
MY neighbour has got an old lead stop cock thats connected to lead pipes thats which is leaking slightly from right next to where you actually turn it from, I am intending on changing this for a new one but Im thinking I will have to fit a leadlock on each side then connect a bit of copper to connect to the new stopcock.
His system is a gravity fed system and im just wandering how I am going to drain it.
Im thinking if I turn off his stopcock outside then let the cold water taps run untill it drains down?
I have read on the how to area of this site about draining wih a cicstern but am not sure if he has one, he has a big water tank in his loft along with his cylinder but am not quite sure if he has a cistern. I also read that a cistern is usually folded to fit through the loft hatch and as the black tank is huge and would never of fited through his loft hatch I think it is a cistern.
If it is a cistern since I am cutting the mains from outside would I still need to drain the system down? or would water flow back?
I am thinking that maybe I could just cut the water from outside and it should be ok?
If you could please advise me on this It would be much appreciated
Thank you
Thank you
