changing a radiator
A
armour
Hi all ,I'm decorating at the mo and would like to change a radiator. The old one is showing signs of age. My problem is that the old rad is 147cm long and I cant find one the same size. The closest I can get is 144cm. Does anyone know where I can get one of the correct size or is there an adaptor I can get as I'd rather not replumb.
Thanks in advance
Yes you would need 1 x 20mm extension and 1 x 10mm and basically you take out the tail where your valve connect and put these in instead.
Obviously when drained :D
