Changing Bell boxes - Too many wires
14 Apr 2010
Staffordshire
I am changing from a Flashguard 100 XL bellbox to a Texacon Odyssey 1/1E
The main unit is a OPTIMA XM6.
There are six wires going into the 100 XL bell box, these are,
Tamper settings NEG. SUPPLY D=RED . A=BLACK. TRIGGER B=BLUE (only the neg terminal is used on the trigger section). TAMPER. T=YELLOW (only OUT used on tamper section). STROBE. NEG=GREEN and POS = WHITE
On the Texecom Bell box there are only five connections these are, +VE supply A = RED. -VE Bell B = Blue.. -VE Tamper C=Yellow. OV D=Black. and -VE Strobe S=Green.
There is no terminal for the White wire (+ Strobe).
I would also like to stop the strobe flashing when the siren stops
Connect as you have typed but --
Forget about the green wire and the white (cut the end of the wire and put a bit of tape over each one) then put a wire link between -ve bell BLUE and -ve strobe.
This unit gets its +ve strobe internally off the board and if you wire as above.
The strobe will now follow what the sounder does.
Hope this helps
Grahame
Hope this helps
Grahame
Works great.
Thanks for your help Grahame
