Hi-while I'm online i thought i might ask a quick question - I am going to put a BS12 part 2 float valve in my friends cold water tank-as his is leaking slightly and will only get worse. His stopcock is very stiff (even with leverage it is not able to shut off fully). I thought I'd freeze the pipe near to where the rising main enters the cold water tank, cut it, add a compression isolation valve (slotted type) then add a bit more pipe up to the water tank and install the new float valve. Is this satisfactory? I just want some re-assurance really??
The pipe freezing kit I have says it works up to 7 bar of pressure and I knw in the london area the pressure is usually 2.5 bar, 3 bar max! so this also should be fine?? I'll also have a 15mm stop end in hand in case the pipe freezing kit for some reason is faulty!!!
