I want to change the fluorescent tube in the kitchen to spotlights or track lighting - I think track lighting will probably be better because the wires don't come into the centre of the room - so spotlights would be offcentre.
I just want to check if swapping it over is going to be pretty idiot proof, ie for me to do.
I've got two twin and earth cables coming in.
The two brown wires from each cable are joined together into a block connector - attached to nothing.
The two earth wires are sleeved together and go into the earth of the light fitting.
One blue wire from one cable goes into the light fitting block connector.
The other blue wire has been sleeved with brown and it goes into the light fitting block connector.
Does this sound like it's just going to be a simple swap over to a new light fitting? Is track lighting any different to wire up than normal lighting?
Sorry if I'm being vague - but you might guess, I'm no sparky!!! I'm not stupid and can do a straight swap but I don't think I've got the confidence to do anything more technical than that.
Any pointers much appreciated.
Alison
Alison
