Just moved into a new house and changed the lock - like for like replacement with a yale night latch (https://www.screwfix.com/p/yale-bs-night-latch-polished-chrome-60mm/)
Lock went on fine but an issue I’m having now is that the latch itself seems to be too long. Previously you could shut the door and it would close itself because the door was striking against the sloped bit of the latch. Now it will only shut if you put the key in and retract the latch, as otherwise it’s striking on the flat bit of the latch before the sloped bit.
How do I adjust this so that it works like the old lock?
thanks
thanks
