Presently there is an oil Rayburn cooker, semi-gravity setup, open vented.
I need to install a condensing oil boiler. How easy is it to install a System Oil Boiler and seal the whole of the central heating, I will check expansion vessel against system contents to see if size is ok.
1. remove CH F&E tank
2. Cut back both pipes to tank and cap off. Remove mains supply to tank.
