Hope you can help, I have an outside tap (think I got it from Wickes or one of the DIY places years ago),anyway, it comes through the wall and I think it had a push fit connector on it ( Its certainly not a compression and its plastic), the fitting the connects to a washing machine hose,I have a drip from the hose, I could try the with tape (PVA?) see if that stops it, but ideally I would like to remove the push fit fitting, Is that fairly easy to do?
Once removed I thought about putting a flexible hose on, something like:-
http://www.screwfix.com/prods/93580...ble-Hose-15mm-x-15mm-10mm-bore-500mm.Although the other end of the washing machine hose goes to something like :-
http://www.screwfix.com/prods/18071/Plumbing/Washing-Machine-Accs/Washing-Machine-Valve-Without-C-V
So would:-
http://www.screwfix.com/prods/77154/Plumbing/Flexible-Hoses/Flexible-Tap-Connector-15mm-x-0.75"x-300mm
Be better?
Would that work?
Thanks in advance
Steve
So would:-
Be better?
Would that work?
Thanks in advance
Steve
