Changing radiator valves
4 Apr 2010
Humberside
Can you change radiator valves on micro bore pipework just like you can on 15mm pipework?
yes
unless you have twin entry valves which are not obsolete (as far as I no) so you will have to re pipe ether side
personally if the old nut fits the new valve no
If it doesn't then I would try to get the olive off
if all fails id cut and solder a new piece of pipe
thanks with 15mm do you usually leave the olive on if the nut fits too? Have always cut them off.
Yeah, recycle where possible :), a few turn of PTFE just to take up the slack in the ridge on the olive from the previous fixing to ensure tightness
