Channelplus H37XL Heating Controller
right just looked at diagram again, the voltfree contact is the switch to fire the boiler, Yes?
Yes, well thats what i think it is.Workks ok. Being its the weekend, can't get tech support from hep till Monday, but plumbers r coming monday to test
no it is. we wired up a large system with set back room stats in each room, all coming back to me now. like you say all boiler inputs wired in parallel. the programmer input switched live goes into time I term.
Can you explain NSB, night set back theermostats. Too late for me now as i've wired up thermos in 3core and e. What is it for?
the set back room stat kicks in when under floor heating is off and sets temp back 4 deg so the room doesn't cool down to a point where it would take a long time to bring it back up to temp (efficiency really) so basically under floor heating is allways on unless you actually switch off boiler/programmer
I can't have tried only switched live onto time 1,as it now works!!!
There's just one other thing, when controller calls for underfloor and there is no demand from thermostats pump does not come on(which is correct)
But volt free output for boiler closes calling for boiler.
I thought the purpose for that output was for above conditions :?:
No, nothing. Does not matter now, at least everything is working. I will ring Hepworth in morning to confirm
Thanks for replies
