chased in Pipes - which plaster?
16 Nov 2006
Hi
The plumber has just fitted a new CH system to my parent bungalow. Boiler in loft and chased pipes into the walls to connect to the Rads.
I need to plaster over the chased in pipes (plastic 10mm)
Can I ask what is the best plaster to use. Just ordinary plaster our would or recommend backing plaster first. ?
P.S I take it PVA will not cause an issue with the pipes ?
No just clipped into the cavity. Should they be covered?
Unless you have pics its hard to say, but if there clipped to the brick work and you plaster straight onto them. chances are the plaster will crack...
