Could someone please advise the cause of this problem. Drayton RT111 trv, one of three fitted back in january. is it just duff or could something else be causing it? thanks.
I had one of those recently ............ Don't ask me why I did this but it worked ...... I just changed the Stat bit (top bit) ..... Worked a dang treat ...... It used to rattle like a ferker......... Most annoying when I w0s watching neighbours
thanks for replies. according to drayton web site these can be fitted on flow or return. they belong to a friend who was justgoing to get a replacement head but I thought i'd ask here first. thanks again.
just thought i'd give an update to this. a new identical valve was aquired and the new head used to replace the chattering one. the noise still persists. depressing the pin with the head removed causes a clunking noise and sometimes the chattering noise can also be duplicated. i guess this means that the valve body itself is kaput. is this likely? TIA.
