Hi, I have an old end terraced house which I rent out (1920s).
I have had an outgoing problem of upstairs damp in an area towards the ceiling and wall below the chimney shaft. I had some work carried out a few years back - the flues capped, however the problem seem to steadily stay the same.
It appears to have got worse in the last few months. A couple of weeks ago I paid another roofer to re-do the leading (flashings?) to the chimney, however after a heavy night of rain this morning I noticed damp on the top of the newly wallpapered wall. Upon going up in the attic I could feel the exterior wall - next to the chimney was still very damp.
Some information:
The chimney stacks belonging to the property were demolished many years ago and the stumped roofed over. However, a brick stack belonging to the neighbour (floating freehold) rises against the West end gable and passes through to verges to this gable.
It is clear that the dampness is penetrating around this stack. The chimney is no longer used. It is also clear that the problem is worse when it rains heavily and when it is windy.
From inside the attic the problem wall - next to the chimney stack - the damp area, which in parts is soaked is an area about 3/4 towards the roof top, the top quarter is dry suggesting that water is not going in through the top of the stack, but the side.
The roofer is now suggesting coating the stack with waterproofing fluid before taking any further steps. This whole area is an unkown entity to me so just seekingadvice. Will the waterproofing coating be sufficient? What else can be done?
Removing the chimney entirely sounds a costly nightmare! Thanks in advance.
Some information:
