Ive got a leak around my chimney, which appears to be leaking down the long (sloping) side and off onto the ceilingbelow.
Had the roofer look at it once and I beleve he reseated some loose lead and then attempted to seal the end of felt onto the lead with silicon and expanding foam due to the felt being in his mind to short, preventing him tucking it up under the lead. Sounded like a bit of a bodge at the time but if it held still spring i have other things to think about on the house!
However, its still pouring in! The felt is shot which i know, probebrly origanal to the house (1940's) although the tiles have been replaced more recently.
My understanding is that the felt in the main is there to keep the wind from blowing rain/snow up under the tiles, with the tiles being the first line of defence. How true does this hold around the chimney? Most lead i have seen has the peice along the bottom ending over the tiles, and the peice of lead down the long side ending onto that, and the peice on the top edge starting under the tiles and end on the peice running down the side. Fine. But what stops the rain running of the long edge of the long peice (if your still following) Which obviously is quite long (say, 3-4ft) and not nearly as wide!
This appears to be the issue, as its the first rafter in from the chimney thats sodden, directly under where i would antsipate the flashing ending.
I wasnt at the house when he did the work, as I work 8 till 5 myself and have very limited flexabilty in that. However I have one day booked off on monday to supervise my cavity walls being filled and loft insulated so would like to try and get him to come then to look at it with me and get it fixed for good.
