chimney noise
2 Jun 2023
Hi there have got a strange noise intermittently coming from wall - there's a vent and looks like an old chimney breast [mid floor flat; also heard in basement flat]. Since Sunday 28th so for 3 days
video here chimney noise
Any thoughts/ideas what this could be?
It's not scratching so doesnt sound like it would be any sort of animals [mice or birds]. Given it's been going on for 3 days - I'm not sure what if anything could be falling and making that sort of noise
What would be best way to investigate - do modern chimney sweeps use cameras to look from top of a chimney stack?
thanks for all the expert advice [i hope] in anticipation
Best
Check for an Amazonian, 12 legged yellow beaked mud beetle. They make that noise during their mating season.
Whats above?
Could be an internal leak if the bathroom is upstairs above it? (or a water tank even higher).
You could try removing the vent cover and having a look, a cheap USB camera will go round the corners & display on your phone.
Best
From the video, it doesn't sound like typical mice or bird scratching. It could be loose debris, a moving chimney cowl, thermal expansion, or even a bird higher up the flue.
Since the basement flat can hear it too, the source is likely in the shared chimney stack. A chimney sweep with a CCTV camera is the best person to inspect it and identify the cause quickly.
