I’ve just opened up a previously bricked up opening in a chimney breast to reinstate a cast iron fireplace. You can see where the original fire was removed - the area was rendered in with cement which I’ve now removed. The replacement skirting was concrete too! First time I’ve seen that.
anyway, I was expecting to find a brick arch at some point, but If there is one it’s way higher than the top off the original mantle.
I’ve got a bit of oak which would make a suitable lintel (and would give me something to secure the new fireplace to), just wondering if this will prove problematic when it comes to making good? ie will the wood move and the plaster (lime) fall off? Only a bit of it will extend out beyond the fireplace itself. I’d rather avoid using a concrete lintel if possible.
many thanks in advance.
John
