We have had a real coal effect gas fire fitted in our louge complete with inglenook fireplace. The problem is that when we have all doors to the room closed, we get a smell of fumes in the room. Initially, we thought it was because the installers did not fit an air vent - so I fitted one. I removed 2 x 9inch bricks and fitted an air brick and covered it with a permanently open "marley" cover in the room. The problem is still there, albeit a little better. Further examination found that the distance between the top of the fire basket and the chimney opening is approx 8 inches more than it should be. This is because the base of the original fireplace was 8-10 inches above the floor level. When the new fireplace was fitted, they lowered the floor of the fireplace to floor level.
unfortunately, the company who fitted the fire have gone bust so I am left to fix the problem myself. As I see it, the solution is to reduce the gap between the top of the fire basket and the bottom of the chimney. The question is how?
I have had the chimney checked and it is ok.
Can anyone help? A picture of the fireplace can be found here
it is the second one down on the right.
