Im new to this forum so please bare with me.
I've recently started the ball rolling regarding a loft conversion with en suite bathroom. I understand they can be quite tricky with regards to building regs etc.
All going well untill yesterday when architect emailed to say building control have informed him that my chimney stack needs to be extended due to me having a very seldomly used gas tiled insert open fireplace in the dining room.
Apparently the stack was reduced in height at some point for some unknown reason.
Now I can get my head round the whole fumes may enter the house at loft height if the height of the chimney / flue is not sufficient enough, although I really dont see what a couple of extra feet is going to achieve. Anyway the architect has informed me that I must have some structural calcs draughted up and a plan for extra restraint via the very expensive structural eng he uses, to compensate for extra load etc and increase the height of the chimney stack back to its original height. The only other option is to brick the fireplace up which we obviously dont want as it serves purpose.
I have done a little research and it turns out there may be a possibility we could install a power flue? Would this be correct? I know I may have to fit a complete fire place to allow for this or is there a possibility a universal type power flue can be purchased and fitted to my existing fire.
I would prefer to do this opposed to fitting a ballanced type flue and have to change the design of the whole fire place with a glass front etc.
Another question would be would it be possible to extend the flue and disguise with a clay chimney pot opposed to the complete chimney stack I dont understand why the chimney stack needs to be extended. Also if a balanced flue or power flue can be fitted with a short extension facing away from the house then how and why must I extend the chimney flue when its at least 2 metres off the pitch of the roof.
Any advice will be whole heartedly appreciated many thanks and kind regards
D
D
