r1 - use an Armeg solid board access cutter. 111mm (or 127mm) cuts hole & circular rebate; a circular 'band' is placed on the rebate which then accepts the cut-out disk which sits flush with the floor, thus providing access and a removable cover. The poor alternative is sawing rectangular holes, bracing below then the sawn-out rectangle sits on the bracing.
