Indeed tho, maybe time to get a few pipework classes
As a starter, you want to minimise the angles and bends on the flexi's at the connection end, look for them to be as straight as you can get them, certainly where they connect to the brass
Thanks guy's, although it was a lash up just to test for leaks on the waste and water pipes prior to fitting the plasterboard. I'll post up another image up once the plasterer has finished.
