Circuit Problem
2 May 2005
Moray
Guys
Mysteriously, there are a bunch of sockets that have stopped working. I assume that these sockets are all on the same circuit and there is a central problem.
I have checked the fusebox and all the switches are in the "ON" position. I suppose I will need to work out which sockets are not working and assume that these are all on the same circuit - but how do I go about identifying the cause ?
Thanks in Advance
Can be a whole bunch of things, could be a break in a radial circuit, either at source or somewhere along the way.
Could be some very dodgy wiring that has finally had enough?
I'll fire up google earth and zoom right in....
Seriously though, could do with more detail and pics (we love 'em) of CU, inside relevant sockets and junction boxes (if there are any)
EDIT: Just because the sockets are not working DO NOT ASSUME they are dead. (Golden rule of sparkying is that)
Could be some sockets fed off a FCU and the fuse (13A or smaller!) has operated due to overload?
Look for a possible plate somewhere that has either a switch with a fuse compartment on it or just a plate with a fuse compartment on it.These take a standard BS1362 plug-top fuse.
