Cistern issue
10 Dec 2008
Jersey Marine
I have a couple of concealed slimline cisterns.
They have started to leak water into WC, this is 100% not down the overflow pipe, as water level is well below that.
Took it out cleaned all … still the same (or worse if anything) …. From empty the infill ‘torbeck type’ starts filling, all is fine until around 50mm deep .. and the water starts to leak …. Assuming that the bottom ‘main seal’ is OK, as nothing gets past that initially, only leaks when it get in over the float, so my logic is that is must be getting past the inner seal.
Are these spares items ?
The main seal aprox 66 OD and 48 ID has No. 14.11.29 1 DAL
The inner seal aprox 48 OD and 30 ID has No. 14.11.30 8 DAL
Picture shows siphon, and the seals in the lower picture.
http://www.mediafire.com/file/p7yqjko0ka1v7ey/Siphon.pdf/file
Copy/paste or drag the pictures directly into this thread.
Expecting people to download some unknown file from an external advert riddled website isn't going to work.
tried site would not let me add pictures ...... MediaFire has no more adverts that this site :-)
