Citroen Dispatch Indicator Relay
1 Jul 2008
Lancashire
Does anybody know where i can find the indicator relay on a 2001 citroen dispatch?
thanks
I'm not sure but it may not have one, may be part of the electronics unless it uses the older system.
Peter
Any idea what could be causing my indicators to not work? Theres no flashing or clicking when i use them started doing it intermittently but now then dont work at all same with hazards
1. Might be worth having a fiddle with the hazard warning switch with an
indicators switched on (ignition on).
2. See if there is a flasher unit listed in the main fuse box?
Tried messing with the switch just get the usual 1 click as i turn them on then nothing after that and cant see a relay listed in the owners handbook
Don't think so, the stalk usually has nothing to do with the hazard warning
Just thought I'd update incase anyone else came across this problem turns out it was the indicator relay and it's located behind the lower cover on the steering column.
