Citroen Xsara Picasso rear lens
1 Feb 2011
Cardiff
I've cracked the driver side rear lens covering the bulbs at the rear of the vehicle. I bought a second hand one today from a breakers yard.Can anyone tell me if I need to take off any panels inside the boot to replace it or whether I can take it off from the outside, thanks
if you can see screws from the outside then thats the way,if you cant then there will probably be a panel you will have to remove to gain access to the unit,which maybe plastic wing nuts.
take a looksie here,
www.citreonpicasso.org.uk
