I inherited a very old Clarke generator, model CPB1200, fitted with a B&S 3.5HP engine, model 130292, type 3204 01. I can't get it to start and tried a compression test and only got 30psi. I suspect the rings are rusted in the piston as it probably has not been run for about 20 years. The engine does not have a detachable barrel so I need to remove the crankshaft to get at the piston. I have removed the flywheel but don't know how to remove the rotor from its taper on the crankshaft. It looks easily damaged so I suppose the usual puller type tools are not suitable. Should I just leave it on, split the crankcase and use a puller on the crankshaft?
