Ive got one radiator that never seems to be that hot, especially at the bottom of it. Ive tried turning all but that one off but it still stays the same. Im guessing that it is full of sludge so im looking at removing it and cleaning it out. Ive got a combi for my boiler, if i turn off the pilot and drain down from the lowest rad drain pipe no more water will enter the system unless i open the filling loop, correct?? I dont want to open the pipes to find it still full of water. Is there anything that normally causes trouble with the rad valves, snapping off etc that i need to look out for? It looks like there is some ptfe tape on one joint, is it best to put a new bit on each joint before fastening it back together? Ive got a few towels ready for when the black sludge splashes everywhere. The pipes do seem to angle a bit off of vertical, maybe around 80 degrees but this might just be because of the rad pulling them out of line a bit.
