Apologies if this is in the wrong topic forum - not sure if it should be here, or in Plastering... Anyway hope someone can assist
Problem is this - am re-doing our hallway which has sauna-esque wood cladding on the walls. Want to strip this off, smooth walls and paint but I've taken the wood cladding off in one place and whilst the plaster underneath is in reasonable condition there is quite a lot of dark brown, very solid dried glue type material on the surface (presumably which was previously holding the cladding onto the wall). How do I remove this? It is in large lumps, and so am not convinced that sanding it down is the right answer - takes far too long . Am thinking that an old sharp chisel might be the answer, and run this along the wall, but thought I'd ask peoples opinion first - I really, really don't want to knock holes out the plaster in doing it. Cheers in advance
