Clipsal RCD
7 Apr 2014
Invernesshire
I need to change my Clipsal RCD Powerguard 80A as the Test button does not cause the breaker to trip. Can anyone help me source one of these. Failing that is there any other RCD that can be used instead.
Clipsal is a brand now owned by Schneider. Any of the better electrical wholesalers should be able to supply one.
Thanks for the quick reply. I have checked Schneider out, unfortunately the Busbar connector terminals are set about 5mm further down. I will have to change all the MCB's to match the depth of the RCD. Failing to get the original RCD, I might end up doing just that.
