Cloak room toilet drainage
20 Jan 2012
Merseyside
I am fitting a toilet on a wooden floor in my cloak room. Below the wooden floor is a 2 foot gap.Can I drop down the 110mm soil pipe down to the concrete foundation then run the 110mm soil pipe flat for 4 metres then when outside of the house have it fall away to join the drain?.Any suggestion please.
1:40 is the recommended minimum though you can still have success with much less fall provided you are very accurate. It also makes a difference how 'busy' the pipe run is.
For example, a 6m run of plastic pipe will run smoothly with as little as a few inches of fall provided it is arrow straight with no branches or such like.
However, running level for any distance is not a good idea.
Sorry, but unless a 4" drain was absolutely impossible I would never entertain a Saniflo. They are the devils own work when they go wrong. :mad:
Fit some graduated blocks under the 4" pipe to achieve a 1 in 40 fall.
Only fit a macerator if you intend moving house before it fails.
