Looking to "upgrade" my internet access by moving to fibre - BT Infinity or similar, not Virgin.
Currnetly my BT Mastersocket is in a cloakroom under the stairs. THe Cloakroom has a loo and small wash-hand basin.
As I understand it having BT fibre means a new BT faceplate and modem router nearby - obviously with its own power supply.
I also understand that the PS is one of the "WallWart" things.
Is it "allowed" to have a conventional socket in such a cloakroom? If not what sort of socket might be suitable. The current BT socket is above and behind the loo on the window frame and about 100 cm from the basin.
Getting a feed to a new socket would be easy as the CU is directly next to the cloakroom in a "small" understairs cupboard. - large enough to kneel up in, and with a twin 13amp socket on a RCD protected circuit so no need to enter the CU.
The only other solution would be to use an extension from the BT Mastersocket to your current location 30 ft further on where the current modem sits. This is done by using one of the NTE faceplates like this http://www.tlc-direct.co.uk/Products/GPNTE5ADSL.html.
