Close coupled cistern leaking
1 Sep 2007
Sussex
My close coupled cistern has started leaking all the time, not just on flushing. I believe this is the seal between the bottom of the cistern and the siphon but should I replace the donut washer as well while I've got it off ?
yes
and see if you can get some stainless coachbolts bolts and wingnuts for next time (6mm on ebay I think)
you'll soon know why.
and a bit of silicone grease.
thanks chaps.
Is it also ok to blame the wife for the leak by claiming she "sits on it funny" ?
more likely just age
but cistern bleach blocks (which are very good for removing limescale) do shorten the life of rubber parts.
If you have a ballvalve with a stem going through the bottom of the cistern, this might be a good time to change its rubber seal. Consider a new Fluidmaster or Torbeck filling valve and flusher, they are amazingly quiet.
