closed
The lath is in poor condition if you ask me, I would need a close look but it looks like it has had it's day. Might be best removing the lot and either boarding it or lath it. I suspect most plasterers would tell you to overboard but in this case I suspect you will be asking for trouble.
thanks for your response Peaps..
the ceiling in question, ive actually already taken the decision to pull it down completely and board it, the question i have is regarding the artex, could it be asbestos?
the artex i have there, is actually all over the house, on the landing the halwlay, and on some of the walls not just ceilings, so i want to get rid of the lot.. its just they were the only pictures i had to hand of a closeup of the artex to post
Artex can have it in if it's over 20 years old or so. But the levels are not a danger if you don't do this for a living. Get a mask rip it down and give the house a good clean. Don't scrape it or sand it because you allow it to become airborne. If you just rip it down as it is 99.9% of the dust will be from the lime render and all the crap above the ceiling.
Artex can be removed without a specialist company, say's it all really.
ah so on the other rooms, scraping it back to make it flatter for plastering isnt a good idea then in case its asbestos
maybe board over that or just layer an layer the plaster on until its covered
i personally would not overboard it, id take it all out. Then you can insulate, put lights in ( spotlights ) move switches etc.
It'll be a bit messy for a bit but if you have decided to get rid of the artex somehow, may as well get rid for good. It may cost you a couple of quid more to get it removed ( unless you rip it out yourself ) But its worth it.
ditto
