Im about to decorate my bathroom and need to switch off the radiator, I hope without shutting down the whole system, my understanding is with my central heating system the bathroom does not have a thermostatic valve so it does not get turned off so the heat has somewhere to expand if all other radiators are turned off, as it is now cool enough to start using the heating system would I be right in thinking as other radiators will be open and in use I can safely isolate this radiator without risking any damage to the system, sorry if thid is a ridiculous question, but thought it better safe than sorry to check
thanks in advance
if it helps I have an ideal mexico floor standing boiler, hot water cylinder, f&e in loft and 6 rads all but the bathroom have thermostatic valves very old timer that is set to constant and operated purely through hallway thermostat.
thanks in advance
