- Joined
- 31 May 2019
- Messages
- 1
- Reaction score
- 0
- Country
Make : Volkswagen
Model: Golf 2.0 TDI
Engine size/Type : 2.0
Year : 2013
Mileage : ALMOST 70K
Hello guys , I have an issue with my clutch fluid i think. There was some leakage under my car, like tiny drops of water but not that much but i wasnt really sure what it was. I drove later today for about and hour-2hours which were fine and my gears were working normal. Suddenly, my clutch wouldnt come back up after i fully pressed it to change gear and the gear change was really hard and sometimes would not lock in properly. I then saw more water dropping where I was parked and knew there was a problem so tried to drive it home but on the way home , the clutch completely wouldnt work and i could not change gears. I did some research and found out about master and slave cylinders etc but not sure if my problem is exactly that or if i can just top up some clutch fluid and then fix the leak. Please help if anyone has any solutions. thanks
Model: Golf 2.0 TDI
Year : 2013
